The Remove Orphan Objects and Unused Resources measure will not remove all unused constructions in the model. The CheckUsedConstructions * Warning * is not that important and can be ignored. If you want to remove the constructions that the warning listed, you must go to the constructions tab and manually remove each construction within the construction sub-tab.
The Remove Orphan Objects and Unused Resources measure will not remove all unused constructions in the model. The CheckUsedConstructions * Warning * is not that important and can be ignored. If you want to remove the constructions that the warning listed, you must go to the constructions tab and manually remove each construction within the construction sub-tab.sub-tab.
