You will not see anything in space field for default construction set unless you have set one specifically for the space. However if you do to the construction field under a surfaces construction, you should see a green inherited construction even for the space that doesn't directly have a construction set assigned.
Some elements in the OpenStudio Application interface show inherited connections, others areas do not.
