Probably best approach is to reset the library to default, and then just load one or the other. You can also use the Space Type and Construction Set Wizard measure from BCL to dynamically build space types fro specific building type, climate zone, and vintage/template combination.
Additional content added:
Following screenshot below you can select and then remove a specific library or you can restore defaults. image description
