Not sure if you are using OpenStudio or different tool, but either way, in SketchUp when you select a group it typically draws a rectangular bounding box, so that is the rectangle you are seeing when you select it. To select or alter specific surfaces in that group double click and you will enter into that group. Depending on your settings, when you enter a group the rest of the model may dim or disappear until you exit the group. You can exit with the "esc" key or clicking someone in the background of the model.
