We update the measure as need for new versions of OpenStudio and EnergyPlus. Going from OpenStudio 2.x was a big change, and for reporting measures SQL queries change with different versions of OpenStudio. If you are using an GUI like the OpenStudio Application or PAT, they offer a way to check for measure updates. if you are not you can get them from the BCL link here, or also from the source GitHub repos.
