**Update to the Update: The GitHub downloads are actually hosted on Amazon's S3 cloud; this is about as globally accessible as you can get. We recommend you try again, and if you still get timeout errors, try using a download manager such as JDownloader to manage the process. A download manager can recover from timeouts, and also can break the download file into smaller chunks, making it more likely to succeed. Good luck!
*Update: I have confirmed with a friend in Iran that there are currently issues getting files from GitHub from there; we will post temporary alternative download links tomorrow. As always, thanks to Mostapha!
Timeout errors can be difficult to diagnose, particularly for international (lots of hops). Assuming you don't get timeouts with other sites, we could try and set up an alternate download location for you to try.
**Update Timeout errors can be difficult to the Update: The GitHub downloads are actually hosted on Amazon's S3 cloud; this is about as globally accessible as diagnose, particularly for international (lots of hops). Assuming you can get. We recommend don't get timeouts with other sites, we could try and set up an alternate download location for you try again, and if you still get timeout errors, try using a download manager such as JDownloader to manage the process. A download manager can recover from timeouts, and also can break the download file into smaller chunks, making it more likely to succeed. Good luck!try.
*Update: I have confirmed with a friend in Iran that there are currently issues getting files from GitHub from there; we will post temporary alternative download links tomorrow. As always, thanks to Mostapha!Mostapha (https://unmethours.com/users/8/mostapha-roudsari/)!
*Update: I have confirmed with a friend in Iran that there are currently issues getting files from GitHub from there; we will post temporary alternative download links tomorrow. As always, thanks to Mostapha (https://unmethours.com/users/8/mostapha-roudsari/)!
