You need to make a system call to the openstudio CLI. openstudio.exe run -w workflow.osw. Your workflow.osw can be as simple as:
"seed_file" : "../model.osm",
"weather_file" : "USA_IL_Chicago-OHare.Intl.AP.725300_TMY3.epw"
The OpenStudioApplication can also be used to configure your model / weather file, add measures etc, and it will create a workflow.osw in the model companion directory (= if you have a file called mymodel.osm you will find a folder next to it called mymodel/ and inside at mymodel/workflow.osw you have the workflow file). This is helpful to see what a valid workflow.osw looks like.
$ openstudio.exe run --help
Usage: openstudio run [options]
Options:
-w, --workflow [FILE] Specify the FILE path to the workflow to run
-m, --measures_only Only run the OpenStudio and EnergyPlus measures
-p, --postprocess_only Only run the reporting measures
--export-epJSON export epJSON file format. The default is IDF
-s, --socket PORT Pipe status messages to a socket on localhost PORT
--show-stdout Prints the output of the workflow run in real time to the console, including E+ output
--debug Includes additional outputs for debugging failing workflows and does not clean up the run directory
Forward Translator Options:
--[no-]runcontrolspecialdays Include RunControlSpecialDays (Holidays) [Default: True]
--set-ip-tabular-output Request IP units from E+ Tabular (HTML) Report [Default: False]
--[no-]lifecyclecosts Include LifeCycleCosts [Default: True]
--[no-]sqlite-output Request Output:SQLite from E+ [Default: True]
--[no-]html-output Request Output:Table:SummaryReports report from E+ [Default: True]
--[no-]space-translation Add individual E+ Space [Default: True]
Stdout Options: only available when --show-stdout is passed
--add-timings Print the start, end and elapsed times of each state of the simulation.
--style-stdout Style the stdout output to more clearly show the start and end of each state of the simulation
-h, --help Print this help
$ openstudio.exe openstudio run --help
Options:
$ openstudio run --help
Options:
