Hi, the web tool may have trouble handling the amount of data in your project. You can still see the SA results in data form in jEPlus+EA. Open the project and go to the last tab named "Json Data", you will find the entire dataset of your project - see the screenshot attached. Search for "analyses", it will take you to the section where your SA results are. You may need to scroll down a bit to find Sobol results.
