Hi, You can use Revit system analysis to run whole building simulation using embeed open studio program in Revit. Once you run the simulation inside Revit, a temporary folder is created in following path with files for Eplus simulation (Including IDF file)
C:/Users/User/AppData/Local/Temp/
