The Merge FloorSpaceJS with Model measure uses ThreeJS as an intermediary format. That scene is made on line 109 here https://github.com/NREL/openstudio-model-articulation-gem/blob/develop/lib/measures/merge_floorspace_js_with_model/measure.rb#L103-L117.
You may be able to update that to export a ThreeJS file One thing to keep in mind is an update to this measure in next few months will go direct from FoorSpaceJS to OOSM without using ThreeJS. The ThreeJS methods in OpenStudio will be deprecated and then removed eventually.
David
You may be able to update that to export a ThreeJS file One thing to keep in mind is an update to this measure in next few months will go direct from FoorSpaceJS to OOSM without withouot using ThreeJS. The I don't know abuot long term support of the ThreeJS methods in OpenStudio will be deprecated and then removed eventually. OpenStudio.
David
