There's no real question being asked, but I assume it's "I got this error, how do I fix it".
Well, the error says it all. You somehow managed to draw a Window (or Door, or Skylight) called JALI2-LEVEL2 that is bigger than the surface SURFACE 161 (Wall, Roof) it's supposed to be on. Inspect your geometry.
Also, even if you have a fully glazed wall, keep a bit of wall on all sides of the window, maybe 5 cm, to avoid getting into problems.
