Hotels >3 stories fall under Group R occupancy per the IBC. So, you could model the baseline as a System 8 (PTHP).
IECC-2021
GROUP R. Buildings or portions of buildings that contain any of the following occupancies as established in the International Building Code:
  1. Group R-1.
  2. Group R-2 where located more than three stories in height above grade plane.
  3. Group R-4 where located more than three stories in height above grade plane.
IBC-2021
310.2 Residential Group R-1. Residential Group R-1 occupancies containing sleeping units where the occupants are primarily transient in nature, including:
  • Boarding houses (transient) with more than 10 occupants
  • Congregate living facilities (transient) with more than 10 occupants
  • Hotels (transient)
  • Motels (transient)
Hotels >3 stories fall under Group R occupancy per the IBC. So, you could model the baseline as a System 8 (PTHP).8.
IECC-2021
  1. Group R-1.
IBC-2021
Hotels >3 stories fall under Group R occupancy per I believe hotels are considered "residential", at least according to 90.1 (check the IBC. IECC definitions, I don't have a copy handy). So, you could model the baseline as a System 8.
IECC-2021
Baseline systems don't have to make sense, they're fake buildings. For example, in 90.1 many multi-zone systems are zoned by floor (i.e. horizontally or one AHU per floor), which isn't how they're typically zoned in practice (usually vertically or east-west or north-south).
GROUP R.90.1-2019 Buildings or portions of buildings that contain any of the following occupancies as established in the International Building Code:
  1. Group R-1.
IBC-2021
310.2 Residential Group R-1.residential: spaces in buildings used primarily for living and sleeping. Residential Group R-1 occupancies containing sleeping units where the occupants spaces include, but are primarily transient not limited to, dwelling units, hotel/motel guest rooms, dormitories, nursing homes, patient rooms in nature, including:hospitals, lodging houses, fraternity/sorority houses, hostels, prisons, and fire stations.
I believe hotels are considered "residential", at least according to 90.1 (check the IECC definitions, I don't have a copy handy). So, you could model the baseline as a System 8.
Baseline systems don't have to make sense, they're fake buildings. For example, in 90.1 many multi-zone systems are zoned by floor (i.e. horizontally or one AHU per floor), which isn't how they're typically zoned in practice (usually vertically or east-west or north-south). buildings.
90.1-2019
residential: spaces in buildings used primarily for living and sleeping. Residential spaces include, but are not limited to, dwelling units, hotel/motel guest rooms, dormitories, nursing homes, patient rooms in hospitals, lodging houses, fraternity/sorority houses, hostels, prisons, and fire stations.
Baseline systems As far as codes go for baseline systems, they don't have to make sense, "make sense", they're fake buildings.
90.1-2019
As far as codes go for baseline systems, they don't have to "make sense", they're fake buildings.
90.1-2019__90.1-2019__
residential: ___residential:___ spaces in buildings used primarily for living and sleeping. Residential spaces include, but are not limited to, dwelling units, hotel/motel guest rooms, dormitories, nursing homes, patient rooms in hospitals, lodging houses, fraternity/sorority houses, hostels, prisons, and fire stations.
I believe hotels are considered "residential", "residential" (check the IECC definitions), at least according to 90.1 (check the IECC definitions, I (I don't have a copy of IECC handy). So, you could model the baseline as a System 8.
As far as codes go for baseline systems, they don't have to "make sense", they're fake buildings.buildings.
__90.1-2019__
