I don't believe a running-total U-value can be displayed in the Constructions>Contructions tab currently as you assemble your construction. The only place I've found a construction's U-Value is in the E+ results after a simulation run. If it is available pre-simulation, I would like to know also. :) You could use something like THERM in tandem as your testbed, then assemble the same in OS once you get what you want.
I don't believe a running-total U-value can be displayed in the Constructions>Contructions tab currently as you assemble your construction. The only place I've found a construction's U-Value is in the E+ results after a simulation run. If it is available pre-simulation, I would like to know also. :) You could use something like THERM in tandem tandem: use THERM as your testbed, then assemble the same in OS once you get what you want.
I don't believe a running-total U-value can be displayed in the Constructions>Contructions tab currently as you assemble your construction. The only place I've found a construction's U-Value it is in the E+ results after a simulation run. If it is available pre-simulation, I would like to know also. also! :) You could use THERM in tandem: use THERM as your testbed, then assemble the same in OS once you get what you want.
I don't believe a running-total U-value this can be displayed in the Constructions>Contructions tab currently as you assemble your construction. currently. The only place I've found it is in the E+ results after a simulation run. If it is available pre-simulation, I would like to know also! :) You could use THERM in tandem: use THERM as your testbed, then assemble the same in OS once you get what you want.
I don't believe this can be displayed in the Constructions>Contructions tab currently. The only place I've found it is in the E+ results after a simulation run. If it is available pre-simulation, I would like to know also! :) You could Perhaps, currently the only recourse is to use THERM in tandem: use THERM as your testbed, then assemble the same in OS once you get what you want.
I don't believe this can be displayed in the Constructions>Contructions tab currently. tab. The only place I've found it is in the E+ results after a simulation run. If it is available pre-simulation, I would like to know also! :) Perhaps, currently the only recourse is to use THERM in tandem: use THERM as your testbed, then assemble the same in OS once you get what you want.
