The current version of BEopt has the following breakout of heat loss in the lower-left output graph. It is called Delivered Energy, since it includes duct losses as well as the thermal effects of e.g. heat pump water heaters, heat recovery ventilators, and HVAC fan heat. You can read more about it in the BEopt help.
There is unfortunately no way to get more detailed information about the contribution of walls vs windows vs other building components, though this level of detail is likely to be included in the next version of BEopt (version 3.0).
