Instructions on how to build a new EnergyPlus executable file is here:
https://github.com/NREL/EnergyPlus/wiki/Building-EnergyPlus
Then you can run it in either VisualStudio or copy the created exe into your current EnergyPlus folder. Make sure you rename the old exe first.
