I also met this problem.
At least you have to draw the floorplan again if you need it.
But you can draw it on another project and then copy the JSON file into your folder and merge it so that you don't need to configure the other settings again.
Attention! in the floorplan, the name of the rooms have to be the same and components(windows and doors) won't be matched.
