this is a local deployment on your own hardware?
for the deployment issues: check for dangling volumes, instances and containers and docker prune them. that will free up unused docker resources.
for the runtime issues, there is a measure that will delete files in the /run directory of the datapoints. its good practice to delete everything you dont need so the .zip files only contain the info you really need. that lives here
