Thanks for that. It would be even more helpful to share the exact values (or files) and which values seem inappropriate. Some of these values should be identical between models, but I think some will vary depending on the responsiveness of the HVAC system. Your HVAC systems are very different, so that may be a factor which affects your results.
ps, Kudos for examining your results carefully!
pps, The DesignBuilder Data Grid view is very helpful to confirm that all of your inputs are as you "think" they should be. With thousands of inputs, it's easy to miss the fact that some are not as you intend.
