Here is what it seems like each error is telling you:
Errors 1 - 5: EnergyPro is trying to look up Ventilation Occupant Density, Code Minimum Ventilation per Area for Demand Controlled Ventilation, and Code Design Exhuast Air Flow in a table from the provided Ventilation Function Type and Ventilation Space Function inputs. You have either set one of these two inputs incorrectly for a space, or have entered something that EnergyPro doesn't have in this lookup table.
Error 6: Sounds like an Exterior Wall surface named 'srf36812' was defined incorrectly.
Hopefully that helps
