They are being inherited, if you assigned them at a "higher" level of the building. It won't show the inheritance at the lower levels - I am not sure if this is the design intent, or if it just hasn't been addressed yet.
That is to say, if you put construction and schedule sets in at the building level, or to a single storey of the building, they will apply to all surfaces and spaces, unless overridden at a lower level (say, applying a different construction directly to a surface, or a schedule to a space).
You can verify this by applying a construction/schedule set to the whole building, then going into Sketchup and checking the constructions for each surface.
