I don't know if I got your intent. You may want to set a scheduled internal heat source (lights, equipment, etc.) in the zone and avoid setting HVAC systems or any setpoints. EnergyPlus will simulate a non-conditioned zone so that you can see the changes in indoor temperature according to the zone heat balance. In the screenshot, I show you how an unconditioned zone should appear in the OpenStudio application.
