You do not have to fill it out. It is an optional parameter of the Building
object. I thought it was used in the model_create_prm_baseline_building
method from openstudio-standards
to create a 90.1 PRM baseline, but it is not (it instead uses some model_num_stories_spanned
method and never sets the standardsNumberOfStories
parameter.) So I guess it can be some metadata if you want to create measures that read those parameters.
TLDR;
Do not worry about it. It adds additional information to your model, but it is not directly translated into your EnergyPlus simulation.
parameter.) parameter. So I guess it can be some metadata if you want to create measures that read those parameters.
TLDR;
parameter. So I guess it can be some type of metadata if in case you want to create measures that read those parameters.
TLDR;
Do not worry about it. It adds is additional information that you can add to your model, model but it is not directly translated into your EnergyPlus simulation.
