The input file is actually attached to that pdf you linked to. If you have a pdf reader that can access file attachments you can save it.
Or if not, here you go: https://docs.google.com/document/d/1OC_xPpEezlZckQXG-KyCHVUfdoZsRRYcuWWhcgYpMbM/edit?usp=sharing
Now if only someone had thought to do the same with the Carrier WeatherExpert report...
