The SetpointManager:SingleZone:Reheat needs to know what zone inlet node is used to determine the air mass flow rate for calculation of the set point temperature. That field is a required field. For SPM = Setpoint Manager Single Zone Reheat 1, check that the field 1) is not blank, and 2) has the correct name of the zone inlet node you want to use.
SetpointManager:SingleZone:Reheat,
  A5 , \field Zone Inlet Node Name
       \required-field
       \type node
       \required-field
       \type node
