The OpenStudio Application describes it pretty well, but ahead of those instructions I would fist click the green + at the top left and choose the "Service Hot Water Plant Loop", which you mention in your question. It will come in with a pump, water heater, setpoint manager and water use connection. Click on the water use connection to add one or more water use equipment objects.
The OpenStudio Application describes it pretty well, but ahead of those instructions thee I would fist click the green + at the top left and choose the "Service Hot Water Plant Loop", which you mention in your question. Loop". It will come in with a pump, water heater, setpoint manager and water use connection. Click on the water use connection to add one or more water use equipment objects.
The OpenStudio Application describes it pretty well, but ahead of instructions thee I would fist click the green + at the top left and choose the "Service Hot Water Plant Loop". It will come in with a pump, water heater, setpoint manager and water use connection. Click on the water use connection to add one or more water use equipment objects.
