I ran your V9.6 file in the lastest EnergyPlus code and found a bug in the program. If there are multiple AirLoopHVAC:DedicatedOutdoorAirSystem objects then only the first object finds the correct outdoor air conditions used for sizing. I posted a new issue at https://github.com/NREL/EnergyPlus/issues/9325. This model uses the SizingPeriod:DesignDay conditions to find the outdoor weather.
In the fan model the Electric Power Minimum Flow Rate Fraction = 0.2. At flow fractions below 0.2 the fan power will remain constant. At 0 flow the power will go to 0.
Fan:SystemModel,
PAU_Tower12_Office_1 Supply Fan, !- Name
LEED_V4_OFFICE_VENTILATION, !- Availability Schedule Name
PAU_Tower12_Office_1 Cooling Coil Outlet, !- Air Inlet Node Name
PAU_Tower12_Office_1 Supply Fan Outlet, !- Air Outlet Node Name
autosize, !- Design Maximum Air Flow Rate {m3/s}
Continuous, !- Speed Control Method
0.2, !- Electric Power Minimum Flow Rate Fraction
1200, !- Design Pressure Rise {Pa}
0.9, !- Motor Efficiency
1, !- Motor In Air Stream Fraction
Fan:SystemModel,
I ran your V9.6 file in the lastest EnergyPlus code and found a bug in the program. If there are multiple AirLoopHVAC:DedicatedOutdoorAirSystem objects then only the first object finds objects find the correct outdoor air conditions used for sizing. I posted a new issue at https://github.com/NREL/EnergyPlus/issues/9325. This model uses the SizingPeriod:DesignDay conditions to find the outdoor weather.
