You will likely need to use an EnergyManagementSystem:Program to achieve your desired control. A similar plant control scheme based on OAT is demonstrated in the example file: EMSPlantLoopOverrideControl.idf (C:\EnergyPlusV9-2-0\ExampleFiles). Also refer to the EMSApplicationGuide.pdf documentation for more information on creating EMS programs.
