You can use the OSM models located here. This will probably be easiest if you are already familiar with OpenStudio modeling.
Running upgrades through ResStock is possible, but our ability to support is limited, and the workflow to run on AWS is not always working. Buildstockbatch versions for each ResStock release are listed here: https://github.com/NREL/resstock/releases.
Note that we plan to publicly release a dataset of load profiles with upgrades applied in Summer/Fall 2022.
Running upgrades through ResStock is possible, but our ability to support is limited, and the workflow to run on AWS is not always working. Buildstockbatch versions for each ResStock release are listed here: https://github.com/NREL/resstock/releases.https://github.com/NREL/resstock/releases
