You have a night cycle availability manager that will cause this type of oscillation every 30 minutes. You can try removing that manager to see if it really is the cause.
AvailabilityManager:NightCycle,
PSZ-AC:1 Availability Manager, !- Name
Always_On, !- Applicability Schedule Name
HVACOperationSchd, !- Fan Schedule Name
CycleOnAny, !- Control Type
1.0, !- Thermostat Tolerance {deltaC}
FixedRunTime, !- Cycling Run Time Control Type
1800; !- Cycling Run Time {s}
You have a night cycle availability manager that will cause this type of oscillation every 30 minutes. You can try removing that manager to see if it really is the cause.minutes.
