I think I found a bug in our partial fix for large models by increasing stack size. Can you download, unzip, and run the installer at the URL below? Then try opening your model in this new build?
https://github.com/openstudiocoalition/OpenStudioApplication/suites/5379633885/artifacts/169095988
If this works for you, it will be included in the next major OpenStudio Application release.
OpenStudio Application 1.3.1 has been released and includes this fix: https://github.com/openstudiocoalition/OpenStudioApplication/releases/tag/v1.3.1
I think I found a bug in our partial fix for large models by increasing stack size. Can you download, unzip, and run the installer at the URL below? Then The try opening your model in this new build?
I think I found a bug in our partial fix for large models by increasing stack size. Can you download, unzip, and run the installer at the URL below? The try opening your model in this new build?below?
