If you are using the new-ish Construction:AirBoundary object in EnergyPlus, note that the documentation says:
“The two zones separated by this air boundary will be grouped together into a combined enclosure for solar distribution, daylighting, and radiant exchange (including distribution of radiant internal gains).”
There have been some bugfixes for this object since it was first introduced, so it’s worth using the most recent version of EnergyPlus.
