Elements 1.0.6 and below saves modified EPW files using a "line-feed" line ending. However, we have heard in the past that DesignBuilder does not load EPW files that use that line ending style directly -- I believe they are expecting a "carriage-return, line-feed" sequence similar to Windows. We hope to fix this discrepancy in a future release of Elements (as a disclaimer, I help develop Elements).
It is my understanding that an easy way to get around this is to use the "Hourly weather data tool" within DesignBuilder itself. This tool will import the EPW file created by Elements and, in the process, fixes the line-ending discrepancy.
Be sure that you don't have the "Change filename ..." option checked when you use the Hourly weather data tool as it can create problems for the generated file if your location name uses extended characters (e.g., characters with accents) in the name.
Note: these screenshots are from an older version of DesignBuilder (around 2017). Hope this helps.
