No, I don't believe there is something similar for air loops. Plant loops are closed systems whose load simply depends on supply/return temperature and flow rate, as opposed to AHUs which are subject to return air conditions that fluctuate based on internal gains specified elsewhere, in addition to ventilation requirements and infiltration which impart loads on the AHU based on fluctuating ambient weather conditions.
