you can try in the thermal zone tab/Zone ventilation Wind and Open Area.
You can input the opening area, Opening orientation (Effective Angle), Height difference... If you leave the temperature and wind speed values as it is (Minimum indoor temperature: -100°C etc) the model will calculate the wind and stack ventilation taking in to account the wind speed, wind direction and the stack effect of your opening opened all time. If you want to open and close your openings you can change the Temperature and wind parameters.
