I am able to reproduce the bug and have filed an EnergyPlus bug report. In the meantime, you'll have to use the Correlation calculation method and obtain the two input parameters yourself from the weather file or stat file.
I am able to reproduce the bug and have filed an EnergyPlus bug report. In the meantime, you'll have to use the Correlation calculation method input and obtain the two input parameters yourself from the weather file or stat file.
