There's a measure for that.
Look through the MDD file after a run to see what meters are available in your model, download the measure via the OS App, paste in the name of the meter verbatim, and then run again. If that doesn't fit your needs you might need to write your own measure to create a custom meter in EnergyPlus. Hope that gets you started.
Look through the MDD file after a run to see what meters are available in your model, download the measure via the OS App, paste in the name of the meter verbatim, verbatim, and then run again. If that doesn't fit your needs you might need to write your own measure to create a custom meter in EnergyPlus. Hope that gets you started.
