The picture here under loads shows you how to select columns that you want to appear in the custom view, but that may not be your issue here. Going to the custom tab is just a custom view of specific columns.
I expect your issue here is that the load instance multiplier you are trying to change is part of a space type, and you are trying to edit it for a specific space that space type is assigned to. If that is the case, either edit the space type, or create a copy of the space type, edit it and then assign that copy to this space type. You can also get rid of any space type assignment and manually add loads to this space or add additional loads to the space eon top of what come from the space type. What you can't do is to remove selectively some of the loads that come in with the space type without altering the space type.
