You can use the Python Plugin released with versions 9.3, 9.4, and 9.5 to co-simulate with EP. What you need to do is get the handle of the occupancy schedule and then change the occupancy variable in python. By doing so, you can run as many simulations as you want.
You can use the Python Plugin released release with versions 9.3, 9.4, and 9.5 version 9.3 to co-simulate with EP. What you need to do is get the handle of the occupancy schedule and then change run all the occupancy variable in python. By doing so, you can run as many simulations as that you want.
