Most likely cause is that your OpenStudio spaces are not assigned to Thermal Zones. This can be done in the Space tab in the OpenStudio Application which has a column for thermal zone assignment. If you have not already done so you should make thermal zones and those will in turn be connected to the HVAC system.
