It is supposed to be site energy as far as I can comment. With source energy, it refers to primary source of energy.
Example (every word is assumption): You need 9kWh of heat energy at site. You use %90 efficient electric heater, so it receives 10kWh from the grid. Adding grid transmission & distribution losses, you demand 10.1 kWh from a power plant. That power plant is natural gas power plant, it uses 30kWh equivalent of natural gas to supply your demand. So in this example, site thermal energy is 9kWh whereas source energy is 30kWh.
Please be aware that I'm not %100 sure; but even if it's not fully correct, it's definitely something similar to my explanation.
