Hi, If you want to change the way that walls are shown in DesignBuilder you can go to Construction tab and under the Geometry, Areas and Volumes header you can make any changes you want. You can also insert the thickness you want to see in "Fixed Surface Thicknesses" sub-header. I hope it'll help you.
