Ok, bear with me because by default those logs are hidden pretty bad.
I am assuming you are running Windows, in which case it will be in you App Data TEMP folder in C:\Users\{YOUR_USERNAME}\AppData\Local\Temp\. The log is deleted if you exit the interface in OpenStudio. So:
- Run the measure, it is going to show the error, do not exit the Apply Measure Now window.
- Navigate to C:\Users\luisc\AppData\Local\Temp.
- In the file explorer, search for a file called openstudio-standards.log
- You should find it.
The file is going to be in a directory named something like osmodel-1632432699-1\ApplyMeasureNow\run\000_83e77929-f391-407a-8aef-20994f5b7e37, and the other simulation files will be there.
Mark as solved if helpful!
- You should find
it.it.
