The VRF coils do appear to be sizing correctly as far as using the correct inlet temperatures. For the heating coil, the coil inlet temp/humrat are not reported correctly to the coil sizing summary. Regarding the undersized coil issue, do you have a plot of zone temperature and heating coil part-load ratio to show where the coil is undersized?
