You could try:
- Convert a TMY EPW to CSV, replace the solar columns with custom data, then convert back to EPW.
- Use the solar EMS actuators here to override the TMY data. I typically use this in conjunction with an EMS sensor tied to a Schedule:File to read a CSV with the raw data.
Check out the weather converter programs documentation for information on creating custom weather files.
You could try:
Check out the weather converter converted programs documentation for information on creating custom weather files.
