To view the temperatures at the inlet and outlet of the cooling coil you can output the variable: "System Node Mass Flow Rate" for the inlet and outlet nodes. In case you want to declare/change setpoint of supply air temperature you might want to use setpoint managers. For the zone load control, you might want to use Zone HVAC controls and thermostats.
The question is not clear but hope this helps !
