No, no such table exists and no such output variables or meters have such totals by zone. There are some zone-level report variables for internal gains, but not for total energy use. One major problem that makes it difficult is that when there are central HVAC systems, there is no reliable/general way to assign a portion of the HVAC energy used to a particular zone. If you have a special case where all the systems are clearly associated with specific zones, you may be able to construct your own meter report variable using Meter:Custom.
No, no such table exists exits and no such output variables or meters have such totals by zone. There are some zone-level report variables for internal gains, but not for total energy use. One major problem that makes it difficult is that when there are central HVAC systems, there is no reliable/general way to assign a portion of the HVAC energy used to a particular zone. If you have a special case where all the systems are clearly associated with specific zones, you may be able to construct your own meter report variable using Meter:Custom.
