If you successfully ran an EnergyPlus simulation, you can retrieve construction U-factors from the /reports/eplustbl.html Envelope Summary Tables (here, an excerpt from the US DOE Commercial Prototype Warehouse):
You can alternatively just add up the layer R-values (material thickness / material conductivity).
If you successfully ran an EnergyPlus simulation, you can retrieve construction U-factors from the /reports/eplustbl.html Envelope Summary Tables (here, an excerpt from the US DOE Commercial Prototype Warehouse): Warehouse.
