As a workaround until better support is given in the OpenStudioApplication you can do this, assuming:
- Your model is named
model.osm
- Your Surface to add the pool to (bottom one) is named
My Surface
- The PlantLoop to connect it to is named
My Plant Loop
A one liner using the CLI (it's decomposed for clarity at the end of the answer)
openstudio -e "include OpenStudio::Model; vt = OpenStudio::OSVersion::VersionTranslator.new; m = vt.loadModel('model.osm').get; s = m.getSurfaceByName('My Surface').get; pool = SwimmingPoolIndoor.new(m, s); p = m.getPlantLoopByName('My Plant Loop').get; p.addDemandBranchForComponent(pool); m.save('model.osm', true)"
It'll be missing an icon and showing some fields (the Node ones) that you shouldn't edit, but you'll have access to everything by clicking on it on the plant loop:
Decomposition of the one-liner:
# Load
# Get Floor Surface for the pool
# Connect to a plant loop
# Save
