Re Julien's rant above, regarding the poor E+ time conventions. Here is a snippet of python code that might be useful:
def read_eplusout(datafile, year=2018):
ep_datas={}
if os.path.exists(datafile):
    with open(datafile,mode='r') as inf:
        hline=inf.readline()             ##Reads the line of headers
        for hhead in hline.split(','):
            hhead=hhead.rstrip()
            ##Make sure that we read a variable that we want
            ep_datas[hhead]=[]
        ##Creates a huge data structure
        for i, lline in enumerate(inf):
            for hhead,dd in zip(hline.split(','),lline.split(',')):
                if hhead=='Date/Time':
                    tyy,thh=dd.split()
                    mm,dd=tyy.split('/')
                    hh,mmm,ss=thh.split(':')
                    if hh=='24':
                        ddt=ep_datas[hhead][-1]+(ep_datas[hhead][-1]-ep_datas[hhead][-2])
                    else:
                        ddt=datetime.datetime(year,int(mm),int(dd),int(hh),int(mmm),int(ss))
                    ep_datas[hhead].append(ddt)
                    continue
                if dd=="":
                    dd=0.0
                ep_datas[hhead].append(float(dd))
    data_frame = pd.DataFrame(ep_datas)
    data_frame = data_frame.set_index(pd.DatetimeIndex(ep_datas['Date/Time']))
    return data_frame
