~~No.~~
The air distribution unit is limited to one combined component-controller unit; because controls are normally based on the zone thermostat and can work in parallel or series in complex fashion. Since the control and the flow resolution can be complex, each air distribution unit is unique in addressing these combinations and therefore only one is allowed per zone.
https://bigladdersoftware.com/epx/docs/9-5/input-output-reference/group-zone-equipment.html#zonehvacairdistributionunit
https://unmethours.com/question/9443/how-can-i-develop-two-different-air-loops-in-the-openstudio-model/
Edit: actually yes. See example file 5ZoneAirCooledWithDOASAirLoop.idf.
~~No.~~
~~No.~~No.
No.
No.
